It is currently Wed Jul 16, 2025 7:08 am
PostPosted: Sun Feb 12, 2006 1:51 pm
I found this on the Taylor website, and thought it might be of interest here. Shows the Taylor neck joint system which is very similar to the double mortise/tenon joint that's been discussed here, and on John Mayes video.
This link is for a high speed connection.
https://www.taylorguitars.com/guitars/features/ntneck/Video. aspx?file=NT_Neck_High.wmx
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Sun Feb 12, 2006 2:32 pm
This link doesn't get you there...
Tell us the path via the Taylor site
Andy
PostPosted: Sun Feb 12, 2006 2:56 pm
Andy, try it here and select the video in the bottom right. Taylor actually sent out DVD's explaining their neck joint, and I believe the headstock scarf joint, when it was first introduced.
PostPosted: Sun Feb 12, 2006 8:12 pm
youd might also wanna try http://www.taylorguitars.com/see-hear/
its a section of the site with a whole lotta videos in it.
some wood talk, all the factory fridays stuff, interviews and all...
Udi
PostPosted: Mon Feb 13, 2006 1:27 am
First name: Coe
Last Name: Franklin
City: Decatur
I did a repair on a Chris Adjustomatic last fall that had a neck adjustment scheme similar to Taylor`s. It relied on string tension and a setscrew in combination with a fulcrum. Very different! I have a couple of not so good pics of that if anyone`s interested.
PostPosted: Mon Feb 13, 2006 6:10 am
Did eveyone notice? that the extension is never floating, it is always solid to the block. In a post a couple weeks ago we discussed this issue, and saw examples with floating extensions. Notice on a Taylor, if you change the set-back angle shim on the heal you also have to change the extenion shim as well to keep the extenion in full abd solid contact with the neck block.MichaelP38761.5909143519
PostPosted: Mon Feb 13, 2006 10:47 am
looks like a good idea.....sure a lot easier to build in a factory with all those fancy machines!
I think similar can be achieve without the shims but using the double mortise and tenon joint with an extension of the neck running under the FB extenstion!
Just my thoughts!
